2020-08-11 5:59 PM
1) I added portmacro.h in the folder
(\Middlewares\Third_Party\FreeRTOS\org\Source\portable\GCC\ARM_CM4F)
2) I added path for the header file (MCU GCC Compiler > Include paths)
2023-02-01 12:32 PM
I solved this problem by changing the file name, and copying the file to some other directory in this case i copied portmacroz.h file under portable.
