Ho to fix (and to remains fixed) the lower limit of encoder reading in polling mode?
2020-01-12 12:16 PM
I have a simple and trivial question.
I read the registers of TIM3 in encoder mode in polling and so far everything is ok. The encoder is a normal panel encoder with knob.
I want my reading of the encoder register not to fall below a limit (this example: 4) and not to exceed an upper limit (example: 100, 240 0 600)
My serious problem is that I need to limit the reading when the encoder drops below 4 counts. The code I use is this:
else if(machine_mode == AUTO_MODE_WAITING)
// imposta il tempo di trattamento (solo encoder sx)
// ENCODER B (sezione sinistra!)
count2 = TIM3->CNT;
//LCD_LOCATE(1,1);
//LCD_printf("%3d",count2);
if(count2 > 40) count2 = TIM3->CNT = 40;
if(count2 < 4) count2 = TIM3->CNT = 4;
//LCD_LOCATE(1,1);
count2 /= 60;
count2 *=30;
__asm("CPSID i");
sec_total = count2;
min = sec_total / 60;
sec = sec_total - min*60;
sec_total_todo = sec_total;
first_auto_interval = sec_total / 3;
second_auto_interval = sec_total * 2 / 3;
LCD_LOCATE(2,12); // update minutes
printbytedec(min);
LCD_LOCATE(2,15); // update seconds
printbytedec(sec);
}If the knob is turned normally towards 0 (CCW), the count is blocked at 4 and does not decrease further.
If the knob is turned very quickly towards 0 (CCW), often the encoder does not "fix" at 4, but counts further below, restarting from the upper module limit and the reading (count2) I find the is upper limit (that is 40).
How can I remedy the problem? The encoder is read in polling approximately every 100msec.
Here is my TIM3 initializiation routine in encoder mode: (I'm using STM32CubeMx)
* @brief TIM3 Initialization Function
* @param None
* @retval None
static void MX_TIM3_Init(void)
/* USER CODE BEGIN TIM3_Init 0 */
/* USER CODE END TIM3_Init 0 */
LL_TIM_InitTypeDef TIM_InitStruct = {0};
LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
/* Peripheral clock enable */
LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_TIM3);
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOA);
/**TIM3 GPIO Configuration
PA6 ------> TIM3_CH1
PA7 ------> TIM3_CH2
GPIO_InitStruct.Pin = LL_GPIO_PIN_6;
GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE;
GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_LOW;
GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
GPIO_InitStruct.Alternate = LL_GPIO_AF_1;
LL_GPIO_Init(GPIOA, &GPIO_InitStruct);
GPIO_InitStruct.Pin = LL_GPIO_PIN_7;
/* USER CODE BEGIN TIM3_Init 1 */
/* USER CODE END TIM3_Init 1 */
LL_TIM_SetEncoderMode(TIM3, LL_TIM_ENCODERMODE_X4_TI12);
LL_TIM_IC_SetActiveInput(TIM3, LL_TIM_CHANNEL_CH1, LL_TIM_ACTIVEINPUT_DIRECTTI);
LL_TIM_IC_SetPrescaler(TIM3, LL_TIM_CHANNEL_CH1, LL_TIM_ICPSC_DIV1);
LL_TIM_IC_SetFilter(TIM3, LL_TIM_CHANNEL_CH1, LL_TIM_IC_FILTER_FDIV2_N8);
LL_TIM_IC_SetPolarity(TIM3, LL_TIM_CHANNEL_CH1, LL_TIM_IC_POLARITY_RISING);
LL_TIM_IC_SetActiveInput(TIM3, LL_TIM_CHANNEL_CH2, LL_TIM_ACTIVEINPUT_DIRECTTI);
LL_TIM_IC_SetPrescaler(TIM3, LL_TIM_CHANNEL_CH2, LL_TIM_ICPSC_DIV1);
LL_TIM_IC_SetFilter(TIM3, LL_TIM_CHANNEL_CH2, LL_TIM_IC_FILTER_FDIV2_N8);
LL_TIM_IC_SetPolarity(TIM3, LL_TIM_CHANNEL_CH2, LL_TIM_IC_POLARITY_RISING);
TIM_InitStruct.Prescaler = 0;
TIM_InitStruct.CounterMode = LL_TIM_COUNTERMODE_UP;
TIM_InitStruct.Autoreload = 700;
TIM_InitStruct.ClockDivision = LL_TIM_CLOCKDIVISION_DIV1;
LL_TIM_Init(TIM3, &TIM_InitStruct);
LL_TIM_DisableARRPreload(TIM3);
LL_TIM_SetTriggerOutput(TIM3, LL_TIM_TRGO_RESET);
LL_TIM_DisableMasterSlaveMode(TIM3);
/* USER CODE BEGIN TIM3_Init 2 */
/* USER CODE END TIM3_Init 2 */
}Many thanks for any suggestion and/or advice!
Max Mazza
- Labels:
TIM
2020-01-12 4:40 PM
With rapid turning, you probably get to reading the counter when it underflows (which in unsigned is >40).
Don't take the CNT as your output value and don't modify CNT.
Take signed difference betwen successive CNT readings, add this difference to your output variable and limit only that variable.
