Ho do you connect external oscillator to STM32L412 ?
MNapi
Senior III
I cannot find any schematics, what kind of crystal. I want to connect 20 MHz. It seems it is as high as it can go. The datasheet does not say exactly what o connect.
Some of the STM have two pins to connect extearnal oscillator but this one has just one pin.
4 REPLIES 4
Uwe Bonnes
Chief
Connect to PH0-OSC_IN, leave PH1-OSC_OUT open.
David SIORPAES
AN2867 application note can guide you in selecting the proper oscillator.
Should really review the Data Sheet
fHSE is specified as 48 MHz for Voltage Scaling Range 1, 26 MHz for Range 2
https://www.st.com/resource/en/datasheet/stm32l412k8.pdf
Parts using "CK_IN" expect an XO providing a CMOS level clock signal, ie TCXO
Not going to help if part doesn't bond out OSC_IN/OSC_OUT, and only provides PA0-CK_IN input.
