hi i am using NUCLEOG0B1RE development board. i am not able to debug the code on keil ide as the ide abruptly closed but the program is running fine on stmcubeide. can anyone suggest what could be the problem
SSING.31
Imen.D
Hello @SSING.3​,
Have you an Error message? Can you access the device via STM32CubeProgrammer?
Do you have the same problem with any other boards?
Imen
Imen
SSING.31
no i am not getting any error message as soon as i select st-link option in debugger and run keil ide closed. while in cubeide it runs fine. does any setting i need to do in keil ide for nucleog0b1re board.
SSING.31
i am not able to download the code in flash as it crash there only and it is running fne with cubeprogrammer.
