Hello, I would like to make the Grove - 16 Channel PWM Driver (PCA9685) work with an STM32F429I-DISC1 board. Can you help me?
HGanc.1
I would like to do this to control LED strips, however, I have a problem because no matter how hard I try using the HAL_I2C_Master, it doesn't work.
Foued_KH
Hello @HGanc.1​ ,
First, make sure that you are using the correct address and the correct frequency for the I²C communication.
The take an oscilloscope to check the I2C_SDA and I2C_SCL behavior.
Foued
