GPIO pin current info
SKund.1
When a GPIO pin is connected to power an external device via Magnetic switch, from the STM32 point of view how does it know if the Magnetic switch is ON/OFF?
ON -> Device is powered ON similarly OFF.
Can STM32 detects change in current on GPIO pins?
Any suggestions would be much appreciated.
waclawek.jan
There's no provision to measure pin current in STM32. You would need to add your own external circuitry for that.
waclawek.jan
Thanks for clarifying.
