Get one character from the USART
FLamb.2
I want to get one character at position x from the USART.
Here is my current code:
What do I have to do differently?
char *getchar(int position){
	char data[1];
	data[0]=HAL_UART_Receive_IT(&huart2, data, 1);
	return data;
9 REPLIES 9
Peter BENSCH
The USART would receive characters serially, i.e. one after the other.
What do you mean with position x?
/Peter
FLamb.2
I mean, that the first character of the USART is at position 1, the second character is at position 2 etc.
 If on the USART is the text "abc" displayed then a is on position 1.
You have to receive characters as they come in, one by one. You can't skip ahead without losing information.
If you want, you could read them into a buffer and then use that buffer to read out values in whatever position you like.
FLamb.2
How can I do it?
char getchar() {
	char data[1];
	HAL_UART_Receive(&huart2, (void*)data, 1, HAL_MAX_DELAY);
	return data[0];
The interrupt version completes with a callback, returning immediately, but not with data.
You can't use a local/auto variable to store the character in this fashion.
You've either got to do some buffer management via the interrupt/callback, or use the non-IT version which blocks, and might miss things if you aren't listening at the right time.
FLamb.2
@Community member​
@Pavel A.​ has the right solution?
Depends.
The polling/blocking solution falls over if you want concurrent full-duplex or multi-UART functionality. ​
FLamb.2
This solution doesn't work. I get strange characters. See attachement
