2013-01-03 3:26 AM
Hi
After giving 15V to PC3 (ADC3 channel 13), I'm unable to reprogram the flash. It says ''Flash loader program reported an error''. If there is a remedy, how can I go around this?Have I permanently damaged the MCU?Thanks in advanceTerence2013-01-03 4:45 AM
You could try the usual steps, such as mass erase in bootloader mode.
Perhaps the damage is restricted to GPIOC and/or the ADC. But if you had a pin connected to a low-resistance 15V source, chances are high the part is blown.
