Flash loader demonstrator V2.6.0 command line problem
var2
Posted on March 27, 2013 at 10:59
I did not receive response for my previous question;
Here is the exact description of the problem.
Command below
c:\''Program files\STMicroelectronics\Software\Flash Loader Demonstrator''\STMFlashLoader.exe -?
returns
bad parameter [files\STMicroelectronics\Software\Flash]
message.
This is bag.  The version 2.4.0 works correctly.
To the STMicroelectronics software designers.  This is obviously bag in the
STMFlashLoader.exe command line parser.
Please, check and correct the problem.
2 REPLIES 2
trevor23
Posted on March 27, 2013 at 11:46
Have you tried with quotes around the whole file path i.e.
''c:\Program files\STMicroelectronics\Software\Flash Loader Demonstrator\STMFlashLoader.exe'' -?
var2
Posted on March 27, 2013 at 12:07
Thank you very much!
It works.
