EXTI Lines
gdiez
Posted on August 23, 2010 at 09:51
EXTI Lines
3 REPLIES 3
Posted on May 17, 2011 at 14:03
''I´m looking for in SMT32F103VE datasheet the pin description the EXTI lines but I didn´t searched them.''
Like several manufacturers these days, the ST Datasheet is largely just about physical parameters.  Details about the actual operation are in a separate document.
In the case of the STM32, the document you require is called the Reference Manual - see:
http://www.st.com/mcu/familiesdocs-110.html
gdiez
It seems that I hadn´t explain enough well. I´ve RM0008,datasheet; insider guide, PM0056 docs, and I can´t search this data anywhere.
I´m trying to search where docs explains which pins are EXTI, what numbers and why?
gdiez
I´ve done it. There are 16 EXTI lines one per port Pin. So PA.0 is EXTI line 0 and so.
