External power supply instead of USB
Raahul Jagannathan
Posted on June 27, 2018 at 12:01
I would like to power my STM32F446RE with an external source instead of using USB. Can I simply switch the position of JP5 such that it is connecting the E5V pin and the middle pin, and then provide the supply to the E5V pin and ground? Is this all I have to do, or is this entire procedure wrong?
0 REPLIES 0
