Example: PWM on STM32-Discovery Blue LED
Posted on February 12, 2011 at 21:39
Hey,
I just spent a bunch of time sorting out how to get the darn PWM output on the blue LED on the STM32-Discovery board.  After a lot of time pouring over the datasheets and forum posts I was finally able to work out the following code.  Seems to work very well.
    RCC_APB2PeriphClockCmd(    RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
            RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
            RCC_APB2Periph_AFIO, ENABLE );
    RCC_APB1PeriphClockCmd( RCC_APB1Periph_TIM3, ENABLE );
    // Set the Vector Table base address at 0x08000000.
    NVIC_SetVectorTable( NVIC_VectTab_FLASH, 0x0 );
    NVIC_PriorityGroupConfig( NVIC_PriorityGroup_4 );
    // Configure HCLK clock as SysTick clock source.
    SysTick_CLKSourceConfig( SysTick_CLKSource_HCLK );
    // Setup Blue LED on STM32-Discovery Board to use PWM.
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_8;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;            // Alt Function - Push Pull
    GPIO_Init( GPIOC, &GPIO_InitStructure );
    GPIO_PinRemapConfig( GPIO_FullRemap_TIM3, ENABLE );        // Map TIM3_CH3 to GPIOC.Pin8
    // Let PWM frequency equal 100Hz.
    // Let period equal 1000. Therefore, timer runs from zero to 1000. Gives 0.1Hz resolution.
    // Solving for prescaler gives 240.
    TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct;
    TIM_TimeBaseStructInit( &TIM_TimeBaseInitStruct );
    TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV4;
    TIM_TimeBaseInitStruct.TIM_Period = 1000;
    TIM_TimeBaseInitStruct.TIM_Prescaler = 240;
    TIM_TimeBaseInit( TIM3, &TIM_TimeBaseInitStruct );
    TIM_OCInitTypeDef TIM_OCInitStruct;
    TIM_OCStructInit( &TIM_OCInitStruct );
    TIM_OCInitStruct.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStruct.TIM_OCMode = TIM_OCMode_PWM1;
    // Initial duty cycle equals 0%. Value can range from zero to 1000.
    TIM_OCInitStruct.TIM_Pulse = 0;
    TIM_OC3Init( TIM3, &TIM_OCInitStruct );
    TIM_Cmd( TIM3, ENABLE );
Also, below is a useful macro that sets the PWM duty cycle once the output is running.
// Set duty cycle when using TIM3 as a PWM output.
&sharpdefine SetTIM3Duty( val )    TIM3->CCR3 = val
It's neat to see the blue LED ramping and fading smoothly.
#stm32 #pwm #pwm #discovery #stm32f100rb #output
49 REPLIES 49
Posted on June 03, 2014 at 13:12
Any ideas why this is happening?
Yes, randomly declaring variables in the middle of a subroutine is a C++ syntax, for real C the variable definitions need to be made at the opening scope (ie '{') before any code statements.
If your code was in MAIN.CPP your compiler might tolerate it.
chen
Posted on June 03, 2014 at 13:49
Hi
'' #268: declaration may not appear after executable statement in block ''
means you cannot declare variables after code, variables must be declared at the start of a function block.
//TIM 3 Config
void Timer_Configuration_Sec(void)
GPIO_InitTypeDef  GPIO_InitStructure;
// Setup LED as PWM output
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_PinRemapConfig( GPIO_FullRemap_TIM3, ENABLE ); //LED connected to Pin 6, Port C
  TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInitStruct.TIM_Period = Timer_Period_Value;
TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV1;
  //TIM_TimeBaseInitStruct.TIM_RepetitionCounter = 0;
TIM_TimeBaseInitStruct.TIM_Prescaler = Timer_Prescaler_Value_Sec;
  TIM_TimeBaseInit(Timer_Used_Sec,&TIM_TimeBaseInitStruct);
  TIM_OCInitStruct.TIM_Pulse = SetTIM3Duty(0);
TIM_OC3Init( TIM3, &TIM_OCInitStruct ); // Initialize Timer Channel 3 setup
TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
// TIM_ClearITPendingBit(Timer_Used_Sec,TIM_IT_Update);
// TIM_ITConfig(Timer_Used_Sec,TIM_IT_Update,ENABLE);
// TIM_Cmd(Timer_Used_Sec,ENABLE);
I have highlighted the offending lines. Strange the compiler picked up on he 2nd instance?!?
ronan2308
Posted on March 18, 2015 at 19:27
When i run this code I keep getting errors like these;
linking...
.\ro6.axf: Error: L6218E: Undefined symbol GPIO_Init (referred from main.o).
.\ro6.axf: Error: L6218E: Undefined symbol GPIO_PinAFConfig (referred from main.o).
.\ro6.axf: Error: L6218E: Undefined symbol RCC_AHBPeriphClockCmd (referred from main.o).
.\ro6.axf: Error: L6218E: Undefined symbol RCC_APB1PeriphClockCmd (referred from main.o).
I'm new enough to using the board so could be a small thing. Any ideas what I'm doing wrong?
Posted on March 18, 2015 at 19:46
You'd need to add the stm32xxx_rcc.c and stm32xxx_gpio.c files into your project.
/public/STe2ecommunities/mcu/Lists/STM32Discovery/Attachments/13561/keil_stm32l_proj.jpg
________________
Attachments :
keil_stm32l_proj.jpg : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzsG&d=%2Fa%2F0X0000000bSP%2FmFOdz0aHKjmXlFuIbE9eYkjEOVZo7aPVgeUqIZ9l474&asPdf=false
ronan2308
Posted on March 18, 2015 at 19:59
Clive,
I already have those files in my project folder and have the pathway to the folder containing all the files chosen.
Posted on March 18, 2015 at 20:13
ZIP/RAR the project tree, I'll rack it up here and see. The error messages suggest it's not pulling that stuff in.
The other meta-data in the project are the preprocessor defines ''USE_STDPERIPH_DRIVER, STM32L1XX_HD, USE_STM32L152D_EVAL''
ronan2308
Posted on March 20, 2015 at 11:23
Thats my project that I have been trying to get working.
________________
Attachments :
ro4.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzzH&d=%2Fa%2F0X0000000bSM%2Fi9yOef9NeC0erU.HOd.o96yCuxyE1Majaa9o7TBjynU&asPdf=false
Posted on March 20, 2015 at 21:31
Ok, that's just the project definition file, not the project. Doesn't look like you have the defines set.
cerny
Posted on December 13, 2015 at 17:24
I tried get PWM output on pin PA After lot of time I still can't do it. Can you help me please? Here is the code: Comented parts works on PC7, so I tried changed values.
//RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE );
//RCC_APB1PeriphClockCmd( RCC_APB1Periph_TIM3, ENABLE );
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE );
RCC_APB2PeriphClockCmd( RCC_APB2Periph_TIM1, ENABLE );
GPIO_StructInit(&GPIO_InitStructure);
//GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
//GPIO_Init( GPIOC, &GPIO_InitStructure );
//GPIO_PinRemapConfig( GPIO_FullRemap_TIM3, ENABLE );
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_Init( GPIOA, &GPIO_InitStructure );
TIM_TimeBaseInitStruct.TIM_Prescaler = 24-1;
TIM_TimeBaseInitStruct.TIM_Period = 20000 - 1;
//TIM_TimeBaseInit( TIM3, &TIM_TimeBaseInitStruct );
//TIM_OCInitStruct.TIM_OCMode = TIM_OCMode_PWM1;
//TIM_OC2Init( TIM3, &TIM_OCInitStruct );
//TIM_Cmd( TIM3, ENABLE );
TIM_TimeBaseInit( TIM1, &TIM_TimeBaseInitStruct );
TIM_OC3Init( TIM1, &TIM_OCInitStruct );
TIM_Cmd( TIM1, ENABLE );
//TIM3->CCR2 = 1000;
TIM1->CCR3 = 1000;
Posted on December 13, 2015 at 20:06
    /* Main Output Enable, and Input */
  TIM_CtrlPWMOutputs(TIM1, ENABLE);
