Example for SMBus Host on STM32G031K8
SandeepKel
hi,
I'm looking for SMBus Host Controller on STM32G031K8..
The example is for different boards and when porting in done on my target I don't see any behavior as explained in the example.
Kindly provide some pointers.
Pierre_Paris
Hello @SandeepKel,
Here some remarks :
  • Are you talking about the X-CUBE-SMBUS ?
  • Can you tell more about the application you want to create ? Which mode ? n° of slave ? slave reference ? configuration ?
  • Have you consider the chapter 32.4.(12 to 15) of the RM0444 ?
Best Regards,
Pierre
I tried to check example for SMBus Host on STM32G031K8.-NUCLEO-32 EV board.
There is no example for this particular EV board.
The X-CUBE-SMBUS provide example projects for some different MCU and EV Boards.
I want an example for SMBus Master as Slave where we can send some packets from master and receive the same at Slave.
We want to create a driver for SMBus master to communicate with Charger IC, so we want to demonstrate SMBus working between two STM32 .
We tried to follow your examples but there is not much success.
