EWARM linker error
firmanandres
Posted on April 23, 2011 at 00:50
EWARM linker error
picguy2
Posted on May 17, 2011 at 14:32
Look at your Workspace.  Right click Options then Linker, Library tab, check Automatic runtime library selection.  Or, if you are feeling clever, check Override default program entry.  But if you feel clever you should be aware that the default program entry performs pre-main actions.
