Error: Using CubeMx to Generate Project for STM32F429
albhuang
Posted on March 10, 2014 at 03:49
Hi all,
I used STM32CubeMx to generate project for stm32f429, a .ioc file(v510.ioc) was generated(see the attachment). The Keil MDK was collapsed when opening the project V510.uvproj. Why? Did ST had any example(ioc file) to provide for STM32F429I-DISCOVERY or other EVAL?
Thinks a lot!
9 REPLIES 9
Posted on March 10, 2014 at 04:27
[DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/STM32CubeMX%20Project%20files%20for%20STM324xG-EVAL&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&TopicsView=https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/AllItems.aspx&currentviews=65]https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fcortex_mx_stm32%2fSTM32CubeMX%20Project%20files%20for%20STM324xG-EVAL&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&TopicsView=https%3A%2F%2Fmy.st.com%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2Fcortex_mx_stm32%2FAllItems.aspx¤tviews=65
Honestly, I'm staying away from CubeMx for the time being.
zesgen
Posted on March 10, 2014 at 10:12
I get your file V5ioc, opened in my STM32CubeMX (software version MX.4.0.0, firmware version FW.F4.1.1.0) and generated the code. Project file (V5uvproj) was successfully opened in uVision4 (v.4.0), but linked with error (see attached file).
________________
Attachments :
501ioc.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1G2&d=%2Fa%2F0X0000000bkN%2F.m5OUr_8r7uJuLCvI.xgx8juQBpFLoVzyigPYXNrrFQ&asPdf=false
frankmeyer9
Posted on March 10, 2014 at 10:38
Neither did I try any CubeMX project yet, nor Keil uVision.
But your linker error is indicating a source file is missing, implementing the named functions. This might have to do with backporting the project.
I would try adding the required source file manually to the project.
albhuang
Posted on March 10, 2014 at 10:44
zesgen,
  Really, I used uVision4 (v.4.72.10.0) too, I'd try it again.
  Thank you!
Posted: Monday, March 10, 2014 10:12 AM
Subject: Error: Using CubeMx to Generate Project for STM32F429
I get your file V510.ioc, opened in my STM32CubeMX (software version MX.4.0.0, firmware version FW.F4.1.1.0) and generated the code. Project file (V510.uvproj) was successfully opened in uVision4 (v.4.72.10.0), but linked with error (see attached file).
albhuang
albhuang
Posted on March 10, 2014 at 10:50
Fm, Thanks!
Maybe ST could provide the its .ico file with it's STM32F429I-DISCO just like TI always did.
Posted on March 10, 2014 at 14:25
What's wrong with me?
It's a Google Drive share, the service might have regional limits, should be fine in North America and Europe.
I'll attach it here, I got these at an F429 Seminar
________________
Attachments :
MicroXplorer_F429Disco.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1Fx&d=%2Fa%2F0X0000000bkK%2FU6wrYTUx8_xDeaDFObDTdOAijfjPP0AnLKnWEMdBjrM&asPdf=false
fauvarque.daniel
Posted on March 12, 2014 at 13:41
Attached is the same file that you can use directly in STM32CubeMX 4.0 with the STM32CubeF4 firmware.
Daniel
________________
Attachments :
STM32F429Discovery.ioc : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1FF&d=%2Fa%2F0X0000000bkM%2FoJpX_Nw1MUGgaFp4pzFVcXu7t5Gyoa10zh8LwxqYThg&asPdf=false
fauvarque.daniel
Posted on March 12, 2014 at 13:44
Thanks for the feedback, we will provide those configuration files in a near future
Daniel
