STM32F107 Uart 5 always sets MSB when sending
Options
‎2014-03-11 10:56 AM
Posted on March 11, 2014 at 18:56
Hi everyone,
the title says it all. Scope tells me the timing is fine and the signal looks like it should. Receiving on the other end works. Except the MSB always being set to 1, no matter if I try to send values higher or lower than 127. The debugger confirms that all the settings are fine (USART_CR1 - CR3). USART_DR is getting the correct value ( In my case 0x10 ). USART_SR shows no errors either. Any advice would be appreciated.The init looks like this: GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //GPIOC, UART5_TX GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOC, &GPIO_InitStructure); //GPIOD, UART5_RX GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOD, &GPIO_InitStructure); //UART5 -> 2400B, 8-E-1 USART_InitStructure.USART_BaudRate = 2400; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_Parity = USART_Parity_Even; //USART_Parity_Even; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(UART5, &USART_InitStructure); //Init USART_Cmd(UART5, ENABLE); #stm32-f107-uart
Labels:
- Labels:
STM32F1 Series
Options
‎2014-03-11 11:29 AM
Posted on March 11, 2014 at 19:29
Parity is the NINTH bit
USART_InitStructure.USART_WordLength = USART_WordLength_9b;
Options
‎2014-03-12 5:12 AM
Posted on March 12, 2014 at 13:12
*facepalm* thank you :)
