saiteja
Error Handler
  • December 13, 2018
  • 5 replies
  • 1081 views
If i remove while(1){} from Error handler and Hard fault handler is there any chance of it to effect micro controller
    waclawek.jan
    If your program is perfect and never throws an error, then no.
    saiteja
    saitejaAuthor
    actually i am getting an error that's why i am asking is there any effects if we remove that loop
    Tesla DeLorean
    Guru
    December 13, 2018
    Ploughing forward is only likely to compound the failure.
    Output diagnostic information and reset if you must continue. ​
    AvaTar
    Senior III
    December 13, 2018
    If i remember correctly, the core goes into an error lockup if it hardfaults in a hardfault handler.
    And consequently needs a power cycle to continue.
    saiteja
    saitejaAuthor
    there is a function for initialization of pwm in other function code is written that if that function !=HAL_OK then error handler in error handler while(1){}. Because of this the system is hanging while doing operations. so i am thinking to remove while(1) so that my problem gets solved
