Enquiry about the STM32 Chip Programming
Ankur_1
Greetings Sir/Mam,
I have some questions about STM32 MCU Chips. Sir/Mam, I want to know if the STM32 MCU Chip Programming is possible, you may view the video on- https://www.youtube.com/watch?v=ndEeFQ5mi_g&t=106s  , to get about my question. Sir/Mam, I have- STM32U595RJT6Q MCU, it would be very helpful if you could please tell if Chip Programming of this product(s) is possible, and if possible, which Application Notes, Manuals are required for doing it, also, if I design the Breakout Board for this MCU, then is it possible to program it using STM32 Development Board with any MCU or we require the specific Development Board with this specific MCU only, and if their is any other very critical & essential thing(s) to keep in mind while doing all this, if anything among them is possible.
Thanking You,
ANKUR.
Andrew Neil
Sure, STM32 chips can be programmed.
They are based on ARM Cortex-M cores, so programming is via SWD (some support JTAG)
This is a standard for ARM-based microcontrollers:
https://developer.arm.com/documentation/ihi0031/a/The-Serial-Wire-Debug-Port--SW-DP-/Introduction-to-the-ARM-Serial-Wire-Debug--SWD--protocol
You can use any tools which support ARM Cortex-M
ST's own tools are STM32CubeIDE, STM32CubeProgrammer, and the ST-Link:
https://www.st.com/en/development-tools/stm32cubeide.html
https://www.st.com/en/development-tools/stm32cubeprog.html
https://www.st.com/resource/en/technical_note/tn1235-overview-of-stlink-derivatives-stmicroelectronics.pdf
@Ankur_1 wrote:
I have- STM32U595RJT6Q MCU, .
For any ST chip, you can find all tools & resource on the Product Page:
https://www.st.com/en/microcontrollers-microprocessors/stm32u595rj.html
Key documents to study are
@Ankur_1 wrote:
if I design the Breakout Board for this MCU, then is it possible to program it using STM32 Development Board .
Yes, that's possible with many boards, but not all - check the board's User Manual for details.
mƎALLEm
Not clear what do you want to do even after watching the video which is related to ESP32!
Need to elaborate more ..
Andrew Neil
Andrew Neil
@Ankur_1 wrote:
view the video on- https://www.youtube.com/watch?v=ndEeFQ5mi_g&t=106s R.
Like @mƎALLEm I fail to see the relevance of that.
If what you're looking for is a simple development board, then look to Nucleo:
https://www.st.com/en/evaluation-tools/stm32-nucleo-boards/products.html?querycriteria=productId=LN1847$$1=NUCLEO-U5
