Editing IAR .o file
‎2018-03-04 6:26 AM
Hi ST,
I'm using STM32F767 processor.Because of the need of our project,I meet a problem that I don't know how to editing .icf file of
STM32F767
in IAR project.What should I do?And how I should do to add the .o file into IAR project directly by modifying the .icf file under the circumstance where there is only .o file offered?Best regards,
Frank
‎2018-03-04 7:09 AM
Hi Frank Lee
I do not well understand why do yo want to add with object file.
However to edit linker configuration file .icf do like this:
Go to Project Option (right clic on into project explorer)Select Linker (left) and then Config Tab and EditRegards
‎2018-03-04 7:18 AM
Depending on the tool chain you typically drop objects/libraries into the project, or add them to the linker command line.
To 'edit' object files you'd need some familiarity with the underlying format (ELF)
