Does STM32F4xx support UART IAP?
2015-08-02 8:09 PM
Hi Guys,
I download sample code for UART IAP(AN4657) and try to use on my STM32F405, but till now I havn't made it run.and I found below info from document:Content
STM32L0 HAL Driver 1.2.0.
file:///D:/dev/gogo-lite/st-update/8.3/x-cube-iap-usart/AN4657-STM32Cube_IAP_using_UART/Drivers/STM32L0xx_HAL_Driver/Release_Notes.html
STM32L4 HAL Driver 0.3.0.
file:///D:/dev/gogo-lite/st-update/8.3/x-cube-iap-usart/AN4657-STM32Cube_IAP_using_UART/Drivers/STM32L4xx_HAL_Driver/Release_Notes.html
STM32F1 HAL Driver 1.0.0.
file:///D:/dev/gogo-lite/st-update/8.3/x-cube-iap-usart/AN4657-STM32Cube_IAP_using_UART/Drivers/STM32F1xx_HAL_Driver/Release_Notes.html
STM32L073Z-EVAL BSP Driver 0.0.4.
file:///D:/dev/gogo-lite/st-update/8.3/x-cube-iap-usart/AN4657-STM32Cube_IAP_using_UART/Drivers/BSP/STM32L073Z_EVAL/Release_Notes.html
STM32L476G-EVAL BSP Driver 0.1.0.
file:///D:/dev/gogo-lite/st-update/8.3/x-cube-iap-usart/AN4657-STM32Cube_IAP_using_UART/Drivers/BSP/STM32L476G_EVAL/Release_Notes.html
STM3210C-EVAL BSP Driver 6.0.0.
file:///D:/dev/gogo-lite/st-update/8.3/x-cube-iap-usart/AN4657-STM32Cube_IAP_using_UART/Drivers/BSP/STM3210C_EVAL/Release_Notes.html
STM32L0xx CMSIS 1.2.0.
file:///D:/dev/gogo-lite/st-update/8.3/x-cube-iap-usart/AN4657-STM32Cube_IAP_using_UART/Drivers/CMSIS/Device/ST/STM32L0xx/Release_Notes.html
STM32L4xx CMSIS 0.3.0.
file:///D:/dev/gogo-lite/st-update/8.3/x-cube-iap-usart/AN4657-STM32Cube_IAP_using_UART/Drivers/CMSIS/Device/ST/STM32L4xx/Release_Notes.html
STM32F1xx CMSIS 4.0.0.
file:///D:/dev/gogo-lite/st-update/8.3/x-cube-iap-usart/AN4657-STM32Cube_IAP_using_UART/Drivers/CMSIS/Device/ST/STM32F1xx/Release_Notes.html
CMSIS Version 4.2
file:///D:/dev/gogo-lite/st-update/8.3/x-cube-iap-usart/AN4657-STM32Cube_IAP_using_UART/Drivers/CMSIS/index.html
So I'm wondering whether this IAP sample supports STM32f4XX?Thank you!Daniel- Mark as New
2015-08-02 9:50 PM
Not in that Cube release, but IAP generally is implementable on all architectures.
There are STM32F4 examples using the SPL (Standard Peripheral Library)http://www.st.com/web/en/catalog/tools/PF257903
2015-08-02 11:14 PM
2017-09-13 2:32 PM
Turvey.Clive.002
Hi Clive,
I am looking to implement IAP usingSTM32L053R8T6. I have tried X-CUBE IAP-USART
http://www.st.com/en/embedded-software/x-cube-iap-usart.html
. But couldn't get that working. Is there a similar software for STM32L0xx using SPL?Thanks,
Harsha
2017-09-13 3:45 PM
I don't believe ST released an SPL for the L0 parts, there might be a low level library, and worst case you could build a couple of two line functions to send and receive data on the (LP)U(S)ART.
There are several IAP examples for the SPL code base, seem to recall them implementing Y-MODEM or something similar. The STM32F0 examples might be the most prescient.
http://www.st.com/en/embedded-software/stsw-stm32116.html
2017-09-13 5:01 PM
Yes. There is an option to import LL library from STMCubeMX for L0 parts. Will try to build using the example code for STMF0xx. Thank you for the quick response Clive.
Harsha
2017-09-13 7:28 PM
Part of the light-weight wrappers used on an STM32L072CZ loader with X-MODEM
void outchar(int x)
{ while((USARTX->ISR & USART_ISR_TXE) == 0); USARTX->TDR = x;}int inchar(void)
{ while((USARTX->ISR & USART_ISR_RXNE) == 0); return((int)USARTX->RDR & 0xFF);}Up vote any posts that you find helpful, it shows what's working..
