2018-02-10 07:06 AM
DocID029085 Rev 2
Section 6.15 Virtual COM Port
Makes reference to USART3, no other reference in document, and VCP uses USART1 PA9/PA10
2018-04-26 07:56 AM
Thanks for all your feedback and report typos.
The new revision of
(Rev 3) is now available with correction.Best Regards,
Imen
2018-02-10 10:37 AM
Correct. USART1 is used for VCP. But they should fix many bugs in software first.
2018-02-10 02:07 PM
I think you'll find different people are involved, so it's not like pants where you have to put them on one leg at a time, and pick which leg to start with.
2018-02-14 03:00 AM
You are right,
VCP uses USART1 and not USART3.
I will forward this typo to the appropriate team t
o update the User manual in the coming release.
Best Regards,
Imen
2018-04-26 07:56 AM
The new revision of
Imen
