2017-04-05 11:07 PM
Ball F2 should be PB13 not PE13
2017-04-06 03:01 AM
Hi
Turvey.Clive.002
,Thank you for your reported error. I will raise this internally to fix it in the coming release.
Imen
2017-04-06 07:42 AM
Thanks, the data sheet was internally inconsistent, the Murata LoRa module uses this chip and the PB13 signal, which is why I noticed it here. Please check where else this ball map is used.
