decoding of the abbreviation TI
In continuation of the topic "documentation curve": in the entire document RM0316 there is no decoding of the abbreviation TI for SPI.
6 REPLIES 6
Peter BENSCH
TI stands for the semiconductor supplier Texas Instruments, which sometimes uses a slightly different variant of the SPI protocol for their devices.
Good luck!
/Peter
and how should I understand this by reading the documentation ? why didn't we make a normal transcript for all abbreviations ? and this is not the first problem, when I remember where else I saw a mysterious set of letters, I will write here.
Because knowing there are differences between TI and MOTOROLA SPI modes is assumed to be taught in classes beyond high-school? Bit like MOTOROLA 6800/6809 vs INTEL 8080 type differences in 8-bit external parallel buses.
https://www.edaboard.com/threads/difference-between-spi-motorola-mode-and-spi-ti-mode.324750/
If these things stump you again, try simple word association in Google, there's probably coverage in Wikapedia
https://www.google.com/search?q=spi+ti
I study electronics on my own.
I already found out through Google. but the documentation is not complete if it does not decipher its abbreviations.
