cubemx + usb vcp and stm32f4?
‎2017-02-24 8:51 AM
hey,
I tried to run usb hs + vcp with code created by CubeMX.
In generated code i have changed:
#define APP_RX_DATA_SIZE 64
#define APP_TX_DATA_SIZE 64and included in main.c:
#include 'usbd_cdc_if.h'
also changed:
Stack_Size EQU 0x00004000
Heap_Size EQU 0x00002000
and no luck at all. When pluging in usb cable i got message in linux:
usb 1-1: new full-speed USB device number 80 using xhci_hcd
usb 1-1: device descriptor read/64, error -71usb 1-1: device descriptor read/64, error -71usb 1-1: new full-speed USB device number 81 using xhci_hcdusb 1-1: device descriptor read/64, error -71usb 1-1: device descriptor read/64, error -71usb 1-1: new full-speed USB device number 82 using xhci_hcdusb 1-1: Device not responding to setup address.usb 1-1: Device not responding to setup address.usb 1-1: device not accepting address 82, error -71usb 1-1: new full-speed USB device number 83 using xhci_hcdusb 1-1: Device not responding to setup address.usb 1-1: Device not responding to setup address.usb 1-1: device not accepting address 83, error -71usb usb1-port1: unable to enumerate USB deviceUnder Windows it recognizes as wrong device (it's not related to driver)
any hints how to run usb hs with vcp?
thanks!
‎2017-02-27 2:48 AM
Check the Configuration tab, USB_OTG_FS Configuration, VBUS sensing - must be set do Disable. I don't really know why CubeMX sets it to Enable by default.
‎2017-02-24 11:01 AM
Maybe a hardware problem? Does another USB class work?
‎2017-02-25 8:57 AM
unfortunately no, tried three different boards on the different computers.
‎2017-02-27 2:48 AM
