2014-12-18 11:06 PM
I've Keil project with three targets, when re-generating project in CubeMX and launching the project i get error ''Target '' already exists''. Need to modify .uvproj file by hand to define targets. Anyone else, is there known fix on this?
NOT TOPIC RELATED: 1stly pros, thanks for CubeMX tool, it has proven to save time on verifying HW design. Cons, my personal experiments on that any software which depends on Java cannot succeed has strengthen. I had problems with 4.4.0 when the app did not start - only flashed update dialog and then disappeared, wasted some time installing various versions of Java but couldn't find solution. Luckily my work did not depend on CubeMX by then and by the time new hw revision came in there was version 4.5.0 to install, which solved my problems.2015-01-06 8:08 AM
Not sure what you're trying here. STM32CubeMX supports project generation for only one target at a time. Best Regards
