2018-08-08 8:26 AM
2018-08-08 8:59 AM
Which version of CubeMx are you using?
Can you please share your ioc file for check your case.
With Regards,
Imen
2018-08-08 9:24 AM
2018-08-15 2:27 AM
Hello @mpare.285 ,
Thanks for your feedback.
To avoid this issue you can:
- switch LSE clock to "Bypass Clock source"
- modify LSE vlaue to 32.768 KHz as fixed in DS
-In Pinout Panel change LSE source to "Crystal/Ceramic Resonator".
please feel free to contact me for furthers details.
Regards,
Houda
2018-08-27 5:06 AM
I have tried without fortune.
This is what I do:
1- set LSE clock to "Bypass Clock Source" in pinout panel [OK]
2- modify LSE value in clock configuration panel [OK]
3 - change LSE clock source to "Crystal...". When I do this I get the error on page clock configuration panel
Do you have any other suggestion?
Thanks.
Matteo
