CubeMX 4.20 pin initialization problem in stm32f0xx_hal_msp.c
‎2017-03-24 5:42 AM
CubeMX 4.20 pin initialization problem . Hi, after I installed version 4.20 (no problem on previous version), TIM1_PWM_CH1 on pin A8 din't work (MCU - stm32f030r8t6, IDE - KEIL 5.20 ).
I found that in the file stm32f0xx_hal_msp.c in HAL_TIM_MspPostInit function, not generated string: GPIO_InitStruct.Alternate = GPIO_AF2_TIM1;
‎2017-05-04 5:50 AM
Hi
merkin.roman
I confirm that the issue you reported will be available in the next CubeMX release (4.21) that will be available soon.
BR. Eric
‎2017-03-24 10:05 AM
Hi
merkin.roman
,Your feedback is reported internally for check.
Thanks a lot for highlighting this and sorry for anyinconvenience this may have caused.
Khouloud.
‎2017-03-28 8:08 AM
Hi
merkin.roman
,The issue is forwarded to our CubeMX team and will be fixed in the coming version.
Thanks again
Khouloud.
‎2017-05-04 5:50 AM
Hi
merkin.roman
BR. Eric
