CubeMX 4.15.0 download link is broken
Andrei Chichak
Lead II
Posted on May 27, 2016 at 06:52
The MacOS Cube 4.14 to 4.15 updater managed to wedge my copy, so I blew it away and went to the website to grab the installer for 4.15.
I went through the download link/accept the license/login loop a bunch of times, but it never quite gets around to downloading the file. Even if I log in ahead of time.
Amel NASRI
Posted on May 27, 2016 at 10:29
Hi chichak.andrei,
It will be safer to make the update to the new version using current installation of CubeMX: from CubeMX interface > Help > Check for Updates > Select CubeMX 4.15.
Then you can also update libraries in your repository (CubeMX interface > Install New Libraries).
-Mayla-
