2009-08-18 8:58 AM
Create a .bin file with Ride7
2011-05-17 4:20 AM
Hi all,
I know it´s not the right forum to ask this question, but the Raisonnance´s forum is not very active. (I´ve posted here:http://raisonance-forum.xsalto.com/viewtopic.php?pid=10029#p10029
) So, I don´t find the option to create a .bin file, then if someone know how to do, it´s will help me a lot... Thanks, Vince2011-05-17 4:20 AM
Hi Vince,
You can use this utility to convert hex files from Ride ''obj'' directory to binaries :) format. Cheers, STOne-32.2011-05-17 4:20 AM
Hi STOne-32,
Thanks for your answer, finally I´ve searched the linker´s configuration file and I´ve found this page which describes how to have the choice in the compilator´s menus : http://syslab.asablo.jp/blog/cat/arm/?offset=40 Thanks, Vince [ This message was edited by: lil-vince on 18-08-2009 21:30 ]
