crash system with EEPROM emulation in STM32F0xx microcontrollers
‎2013-04-19 2:04 AM
For my tests, i use a STM32F0 discovery and i download on the ST website, theEEPROM emulation in STM32F0xx microcontrollers
software.http://www.st.com/web/en/catalog/tools/PF258153
When i run this demo project with �Vision 4, the execution of this sofware causes a crash of my debug session. I remark that the crashhappens when
the loop
is used to write
the data
is
larger than the
page size
. But when i execute the same software in step by step, no crash happens ! I suppose that a timing problem. Can you help me ? #stm32f0-eeprom-emulation-bug #forum-says-no- Labels:
Bug-report
‎2013-04-25 2:37 AM
up
‎2013-04-25 2:51 AM
Crashes how exactly, and on what instruction? You provide no code/process to demonstrate the failure. Does it fail every time? The first time? When you run it a dozen times, or modify it?
Before kicking posts, consider why they are being ignored.Up vote any posts that you find helpful, it shows what's working..
‎2013-04-25 7:02 AM
I found alone !!!
FLASH_SetLatency(); !!! Steps for reproduce this bug: - Buy the F0 Discovery board - Download the exempleEEPROM emulation in STM32F0xx microcontrollers
(http://www.st.com/web/en/catalog/tools/PF258153
) - Load - Run - Crash !!!It
is clear
this time?
‎2013-04-25 8:14 AM
- Buy the F0 Discovery board sure, I'll run out and spend some money to help you for free
Crashes how exactly, and on what instruction? You still provide no code/process to demonstrate the failure. Does it fail every time? The first time?
anyhow, I have a good guess. you forget that flash is page based and using some ''EEPROM bytes'' in a page that contains code, of course, makes that page erase. Erik
‎2013-04-25 9:14 AM
It
is clear
this time?
Not much frankly, does it output a message saying ''Crash!!!'', or can you figure out where it is by stopping the CPU in the debugger? Does it get stuck in a loop, the Hard Fault handler? Other useful information might be what tool chain you're using?
‎2015-09-04 12:25 AM
Hi, ST sirs,
I also have the write data eeprom will ''crash'' problem, I found that when the value of data = 0x00, the system will crash.Is that need spacial process when data value = 0x00.By the way, why the data eeprom need erase process?When will the data eeprom need be erase?I just do the read and write procedure. Thank you. Kevin
