2018-09-17 03:06 AM
I am currently working on a STM32 project which I generated for System Workbench for STM32 via CubeMX, and now I want to switch over to Atollic TrueStudio. Can somebody please tell me what changes should I make to my current dev env to work in Atollic Truestudio?
2018-09-19 08:13 AM
The first thing is to save the original project (make a copy) as a precaution if something goes wrong.
Then, open Atollic Truestudio and use the File/Open Projects From File System... menu item.
Select your System Workbench project and import it in TrueStudio. You will be asked if you want to convert it. Just answer yes.
Generally, it's enough...
Best Regards,
Christophe
2018-09-19 08:13 AM
Best Regards,
Christophe
