2018-04-18 8:57 AM
so i'm using the following function :
BSP_LCD_DrawBitmap();
but i can't find the right conversion from bitmap to .C, i'm in a dead end because i can't use Gui i managed to add all libraries to my project and everything but still even the most simple instructions wont display i would really appreciat your help and thanks
note: the attached file contain a Logo.c file from Cubemx' examples that works fine when i add it, i can't tell what is the type they are using neither the converter
2018-04-18 9:09 AM
i found the solution here
2018-04-18 9:09 AM
2018-04-19 11:57 PM
You can also try this excellent tool:
