Configuration settings for STM32H743I-EVAL2 Board
ABeck.1
I am not getting how to start with all the configurations, want to build the project with settings ,,
any projects are there to start with will be helpful
4 REPLIES 4
Should be a selection of buildable projects for the board under the CubeH7 repository trees.​
ABeck.1
from CubeH7 repository trees i imported some project but it is throwing errors, not building, so it will be better if we can get project (CubeMX file and TouchGFX together) with all the proper settings(configurations).
Problem is in settings only I suspect.
Pavel A.
@ABeck.1​ Please tag your message with TOUCHGFX, to attract experts in this thing.
Without TouchGFX, I did a few CubeMX configurations for this board - no problem.
-- pa
I don't know what tool chain you're using nor what error messages you are getting. I've been able to build things with Keil without issues.
