Config all AXI-SRAM as write-thru or Disable DCACHE?
Asantos
If I configure all AXI-SRAM as write-thru.From the performance point of view, Is the same as disable DCACHE?
10 REPLIES 10
Read my post carefully. The alignment requirement is only for the data on which invalidation will be done - receive buffers. Cleaning can be done on any data, including the receive buffers, if needed.
