2015-12-24 02:33 PM
In function HAL_DMA_IRQHandler(), there is a typo in a comment.
Line 777 should say: /* Current memory buffer used is Memory 0 */ and line 786 should say: /* Current memory buffer used is Memory 1 */ The code is correct but the comments are interchanged. The comments for similar logic in other parts are correct.2015-12-28 01:12 AM
Hi HarjitS,
Thanks for the suggestion! I will forward this to our team.-Syrine-
