Code translation
ted korczak
Posted on June 11, 2018 at 08:37
Hi
How to change arduino uno code to STM32F103
void setup(){ pinMode(9,OUTPUT); pinMode(10,OUTPUT); TCCR1B = (1<<WGM13)|(1<<CS10);  TCCR1A = (1<<COM1A1)|(1<<COM1B1)|(1<<COM1B0);  TIMSK1 = 1<<TOIE1; ICR1=511;  OCR1B=0; }   ISR (TIMER1_OVF_vect) { static uint8_t  n=0; OCR1A =  OCR1B= sine_wave[n]; n++; }  void loop(){ }
henry.dick
Senior II
Posted on June 11, 2018 at 20:09
Don't look at individual lines of code but blocks of code and ask yourself what those blocks are trying to do.
After that implement the functionality on your new target.
4 REPLIES 4
Posted on June 11, 2018 at 20:06
You'd be better starting with what you're trying to achieve, and re-implement.
Set up clocks and pins
Program periodicity of TIM
Set up circular DMA to point to Sine Wave table, and configure TIM/DMA to update pulse width at each period update.
henry.dick
Senior II
ted korczak
Posted on June 11, 2018 at 22:25
I am trying to modify simple sine wave generator for stm32f103, post # 21, click on - показать код
http://arduino.ru/forum/programmirovanie/shim-sinusoida#comment-152231
ted korczak
Posted on June 12, 2018 at 05:25
How to do that some links will help.
Similar code for STM32
HardwareTimer pwmtimer2(2); void setup() { pinMode(PA3, PWM); //Pin mode selected pwmtimer2.pause(); pwmtimer2.setPrescaleFactor(1); // Prescaler setup pwmtimer2.setOverflow(10000-1); // 256 ? pwmtimer2.setCompare(TIMER_CH4, 5000); // ? pwmtimer2.refresh(); pwmtimer2.resume(); } void loop() { } // How to tell to produce sine ?
