2024-07-02 12:31 AM
I have a BMA5 accelerometer sensor and I want to change its I2C address. I have enabled I2C1 in cubemx and set pull-up for SDA and SCK lines. I need guidance on the program algorithm and cubemx setting for this task as I am new to this field. Also, I would like to know, do I have to initialize the I2C1_init() again after setting the new address. Thank you.
2024-07-03 8:49 AM
Hi Azad,
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Regards,
Jake
ST Support
2024-07-03 8:49 AM
Hi Azad,
Regards,
Jake
ST Support
2024-07-03 11:37 AM
There isn't a search result for a BMA5. You have a link to a datasheet?
