Cannot install STM32 Cube programmer for MAC
Giulio Zoppi
Posted on February 12, 2018 at 15:54
I'm having troubles installing STM32Cube Programmer under MAC - High Sierra, recently formatted.
The installation process starts regularly and then freezes forever!
Can anyone help me??
Regards :)
3 REPLIES 3
Aymen Abderrahmen_
Posted on March 08, 2018 at 10:11
Hi Giulio,
Can you please give us your java version ? java -version and please indicate in which step you are observing the freeze.
Best regards,
Aymen.
Giulio Zoppi
Posted on March 08, 2018 at 21:03
Ciao Aymen,
Thanks for your reply!!
Here's the output of the query.
java version ''9.0.1''
Java(TM) SE Runtime Environment (build 9.0.1+11)
Java HotSpot(TM) 64-Bit Server VM (build 9.0.1+11, mixed mode).
The installation freezes at the very beginning.
Thanks in advance for your support:-)
Posted on March 09, 2018 at 07:37
Hi Giulio,
Java9 is not yet supported by MAC installer. You have to install java8 if you want to use STM32CubeProgrammer.
Best Regards,
Ayman.
