Can files created on SDCard by the USB MSC example be read on Windows
cosmapa2
Posted on December 15, 2014 at 19:07
Does anyone know if the files created on an SDCard using the MSC example that is included in the USB library can be read when then inserting the same SDCard in a PC?
#sdcard-spi #lmgtfy #sdc #sdcard-fatfs
Posted on December 15, 2014 at 19:48
They should be viable provided you've got the logical block addressing fixed for cards bigger than 2GB. I've posted examples that work properly.
cosmapa2
Posted on December 16, 2014 at 11:48
Sounds great. Thank you. Where can I find your post with the example?
