Can anyone provide some reference or sample regarding i2c slave bitbang implementation in stm32
‎2023-02-07 6:05 AM
‎2023-02-07 7:46 AM
Hello @JMP.1​ ,
You can refer to the I2C WIKI : Getting started with I2C - stm32mcu
Hope my answer helped you!
Foued
‎2023-02-07 8:20 AM
I tried, using Timer and EXTI. It barely works at 200kHz if there is no other interrupt in the STM32.
So my piece of advice: Keep away from trying this.
‎2023-02-08 12:55 AM
thanks for your reply, this post is helpful when iam doing this i2c with hardware module support. i need to implement software i2c for slave
‎2023-02-08 12:56 AM
Could you please share that code, i can just try atleast
‎2023-03-01 6:36 AM
Hello @JMP.1​ ,
Please check this link . It will help you to implement software I2C for slave.
Foued
‎2023-03-01 8:34 AM
Well, you have been warned.. STM32F437 code extract. EXTI on both SDA and SCL, plus a slave state machine interrupt based to grasp the I2C bus bit events, and a spy which put in BV (SW fifo) all the I2C seen events as an ASCII String.
‎2023-03-01 8:34 AM
‎2023-03-01 8:35 AM
‎2023-03-01 8:35 AM
