2015-05-15 9:28 AM
I was running code through a static analysis tool and it found this problem in a number of places:
Array 'HDMI_CEC_DeviceMap[14]' accessed at index 19, which is out of bounds.The problem seems to be that the the arrary is defined as HDMI_CEC_DeviceMap[14];but the loop is using hex. case HDMI_CEC_OPCODE_ROUTING_CHANGE: for (i = 0;i < 0x14;i++)FYI.
