2017-12-25 09:11 PM
I am using ADC in triple regular simultaneously mode (circular mode using FIFO half threshold). EXTI11 is used for trigger the ADC.when I am reading ADC's value it is not coming in sequence .
When external trigger is timer(TIM2) then I am getting all value in sequence.
How can I resolve this problem?
Thanks in advance.
Regards,
Mohit Rai
2017-12-26 09:11 AM
Make sure EXTI11 signal doesn't bounce. Check with a scope, making sure how frequently it triggers.
2017-12-27 02:34 AM
Thanks for your reply.
Now it's working.
