2018-07-31 06:11 AM
When I want to import variables from the .elf file (generated by the TrueStudio, inside the Debug folder) into the STM Studio software, I get the below error. When I press OK and bypass it, it shows a list of variables, but none of them gets imported.
2018-08-09 06:29 PM
Yeah, doesn't look to be parsing the .ELF properly, perhaps @ST Community can forward to staff
2019-03-03 03:59 PM
Hello Hesam,
Did you ever find a solution to your issue? I have encountered the same issue. Any resolution you could share is most appreciated! Thank you and good luck.
2019-03-03 11:11 PM
Not really unfortunately
2019-03-06 10:10 PM
Hello Hesam,
Thank you for your prompt reply. I am sorry to hear that. Let's continue to try and solve the issue. Best of luck to you!
