4bit SDIO not working, but 1bit SDIO working fine.
LPlyu.1
I use CMSIS to write program that transfer data from SD card through SDIO. For my task i need 4bit mode, but it isn't working. When i try to read some block from SD card STBITERR bit in SDIO_STA register goes high, that means that start bit hasn't been detected on all data lines. But when i use 1bit mode all works fine.
MCU: STM32F407VGT6
How to fix this problem?
Check wiring, socket and pull ups.
Show parts and circuit
Try other known working examples.​
LPlyu.1
I am using devebox board, it has soldered socket, so wiring is not a problem.
I use internal pull-ups that should work. And i tried some other working examples, but it didnt work too.
trave.1
have you resolve your problems?
