2021-01-20 4:56 AM
I have developed a custom board using STSPIN32F0A for bldc motor control application. When I am trying to test with Bull Running BR2804 motor, after configuration of pins when I check in Monitor Section, VBUS voltage is 0 Volt and a continuous Undervoltage fault is detected.
What can be the problem?
Any quick help would be appreciated.
2021-01-27 2:22 AM
Please help me solve this issue
