STEVAL SPIN3202 setup
ArchiB
getting following error while generating
MotorControl reference pack not found: "../../../../Middlewares/ST/MotorControl"
I have STEVAL SPIN3202 board for controlling BLDC motor in FOC mode, but while generating I got this error, please guide.
ASA
Hello @ArchiB ,
could you please provide us which version of STM32CubeMx and MCSDK you are using.
Futhermore, could you verify that in your home directory C:\Users\ , it should contain a directory named as your login name and inside this directory you should have a .st_motor_control folder containing a wb2mx.properties file.
Additionally, please have a look at our ST Community guideline to ensure the best support from us "How to write a Motor control post to get a response quickly"
If you agree with my answer, please accept it by clicking on 'Accept as solution'.
3 REPLIES 3
ASA
Hello @ArchiB ,
ArchiB
[PN]: STEVAL SPIN3202 version 3 board
[VERSION]: Using 5.4.8 x cube mcsdk, cubeMX 6.14.0, latest STlink driver
[TOOL]: using MC WB
[DETAILS]:
I have installed cubeide version 1.18.0, and via cube MX i have installed en.stm32cubef0 and en.stm32cubel0_v1-12-0
I have verified that in home directory C:\Users\ , it  contains  .st_motor_control folder but it does not have wb2mx.properties file.
Additionally while experimenting with xcubeprogrammer i am able to connect and communicate with the board
please help
ASA
Hello @ArchiB ,
in your c:\Users\$USER_NAME\.st_motor_control folder, please create an empty file with the name wb2mx.properties
and try again to generate your project.
ps: which STM32CubeMx version are you using and also which version of MCSDK do you have installed?
Kind regards
