ST Motor Control Workbench Code Generation Failed
2020-12-21 3:58 PM
I cannot find a way to get this to work... Already using run as administrator.
- Labels:
STM32 Motor Control
2020-12-23 7:15 AM
I have same problem on below environment.
I think this problem occurs when not use Oracle Java.
- Environment
- common
- Windows 10 Pro (1909) 64bit
- MCSDK 5.4.4
- STM32 CubeMX 6.0
- problem occur
- Adopt OpenJDK 8(x64)
- Amazon Corretto 8(x64)
- problem not-occur
- Oracle Java 8(x64)
- common
2020-12-23 7:15 AM
- Environment
- common
- MCSDK 5.4.4
- STM32 CubeMX 6.0
- problem occur
- problem not-occur
- common
2021-06-21 9:51 AM
The question has been set only to the "STM32 Motor Control" topic (the question is only about the STM32 MC SDK).
Best regards
2023-06-22 11:17 PM
I too have same problem, i don't know how to sort it out
