MotorControl Workbench generate code error:Problem during Server Connexion:IO error Received fatal alert:internal_error
lchen.32
hello,
I use MotorControl Workbench 5.4.3 generate code,but it keeps reporting errors,I try many times,I need help.
the error message is as follows:
Unexpected return value sent by Updater:0
1 REPLY 1
Laurent Ca...
Lead II
Dear @lchen.3​
It will probably change nothing, but just in case, could you update your STM32 MC-SDK version?
And then please post a new screenshot.
Best regards
