2025-12-28 4:52 PM - last edited on 2025-12-29 12:18 AM by mƎALLEm
Motor Proiler 识别无刷空心杯电机的时候,卡在28%,套件用的是
Translation:
When the Motor Profiler identifies a brushless coreless motor, it gets stuck at 28%. The kit uses...
2025-12-29 5:34 AM
2025-12-29 5:34 AM
Check the MCSDK documentation in the above section.
2026-01-19 4:48 AM
I used it on coreless motor, motor profiler is not mandatory. What motor are you using ?
