Motor Control Work Bench: Code generation error. ---- Please help to check what's the problem?
John.Li
Tool & Version: Motor Control Work Bench 5.Y.4
Cube MX: V6.8.1
FW: 1.11.4
Create the new project as below:
kh_placeholder.pngCode generation error:
kh_placeholder.pngLog detial:
kh_placeholder.pngI had tried to slove the problem in following way:
a) Use the direct path to instead of relative path; ----
Direct path: D:\Software Install\MC_SDK_5.Y.4\Middlewares\ST\MotorControlkh_placeholder.pngmodify in the config file: wb2mx.properties
kh_placeholder.pngb) Use the recommand ​FW version: FW1.11.3 ---- Problem still;
c) Install Motor Control Work Bench 5.4.8 ---- Same problem;
Does anyone have the same problem? Any suggestion?
Zied b.
Hello, I apologize for the late response. I would like to help you but the images do not seem to be displaying correctly, can you please check them.
If you agree with my answer, please accept it by clicking on "Accept as solution".
